[Qgis-user] Format GETFEATUREINFO request from QGISwebserver
Carles Vico Blanco
carles.vico at geografos.org
Fri Mar 20 04:08:31 PDT 2015
Thank you very much for the reply, but I have a question of your answer.
When you say: "The latest release", I understand the QGIS 2.8, that's
correct? And then, I need to install the QGIS Server Python plugin on QGIS
Server, as you say here
http://www.itopen.it/qgis-server-python-plugins-ubuntu-setup/ , or It's no
necessary from the latest release of QGIS Desktop?
I'll try it and I tell you my result!
Thanks a lot!
Carles
2015-03-20 10:47 GMT+01:00 Alessandro Pasotti <apasotti at gmail.com>:
> 2015-03-20 10:26 GMT+01:00 Carles Vico Blanco <carles.vico at geografos.org>:
> >> > Hi, I'm new in Qgis-user List.
> >> > I wonder if it is possible to customize the html response to the
> request
> >> > "GetFeatureInfo" held by QGIS Web Server in the same way as is done in
> >> > GeoServer, MapServer or ArcGIS server with a template, css ...
> >> > For now, the result of my GETFEATUREINFO request takes certain html
> >> > styles if displayed in the QGIS Web Client, but not shown in styles if
> >> > displayed in another mapviewer. To do so it, I need to act on the
> html file
> >> > styles but I have not found. I dont know if it is possible in QGIS
> Server?
> >> > Thank you very much!!!
> With the latest release you should be able to alter GETFEATUREINFO
> response quite easily by writing a custom QGIS Server Python plugin.
> I would try with a simple regexp to inject the URL that points to your
> custom CSS.
> Alessandro Pasotti
> w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150320/1728d423/attachment.html>
