[Qgis-user] update "processing" plugin
    Werner Macho
    werner.macho at gmail.com
    Wed Mar 25 03:03:46 PDT 2015
Hi again
> Still the problem remains : "processing" metadata file should indicate that
> the minimum version of this update is for a newer QGIS like 2.6...
You are completely right .. I think (though not sure) this should only
be a matter of changing
qgisMinimumVersion=2.0 to
qgisMinimumVersion=2.4 in the metadata.txt file ..
(or 2.6 - as I don't know when the necessary dependancy changed)
I will ask the devs to take a look at it ..
Thanks for the hint anyway.
regards
Werner
