[Qgis-user] rule based classification - attribute based on other layer
Junior Delaz
delazj at gmail.com
Wed Mar 25 11:11:21 PDT 2015
Hello,
You may give a look to *getFeature* function (combining or not with
function like *attribute* or spatial ones). There is also *RefFunctions*
plugin that may help to use values/fields of another layer.
But unfortunately, there is no list of such layers nor their fields in the
dialog. You need to write them yourself and their values.
2015-03-25 18:14 GMT+01:00 Matteo Ghetta <matteo.ghetta at gmail.com>:
> Hi all,
> very simple question.
> In the rule-based classification (vector) is it possible to use values of
> another layer loaded in QGIS?
> For example. Point vector and I want to display as red each feature that
> has a value greater than a value stored in another point layer (or in a
> table).
> In the expression builder there are the fields of the active layer.
> Is it possible to call the fields of other layers?
> Thanks
> Cheers
> Matteo
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150325/2e66b842/attachment.html>
