[Qgis-user] Query expression bugs with NULL Values
José Carlos Martínez Llario jomarlla at cgf.upv.es
Wed Mar 25 12:07:44 PDT 2015
Hi List,
Im using some data from OSM, I used this data directly from osm file and
converted to shape file too. In both cases same results:
The layers has 4635 rows:
"amenity"  <>  'restaurant' returns 37
"amenity"  =  'restaurant'  returns 11
The layers has 48 NULL values, so it means that amenity"  <>
'restaurant' does not take into account the null values.
Hope this is a bug and not the correct behaviour.
Im using QGIS 2.8.1
PD: There are more weird results with the NULL syntax. for example:
THIS IS OK
"amenity" is not NULL returns 48
"amenity" is NULL returns  4587
THIS IS WRONG (if null values can not be treated as a text in the syntax
it shouldnt work in both cases or throw some error)
"amenity" <> 'NULL' returns 48
"amenity"  =  'NULL'  returns 0   ????
cheers,
http://cartosig.upv.es
Producción Cartográfica y SIG.
Dpto. Ingeniería Cartográfica.
Univ. Politécnica de Valencia.
