[Qgis-user] QCompleter in QGIS form
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Sat Mar 28 12:32:06 PDT 2015
Dear all,
Thanks to Nathan`s excellent example here:
http://nathanw.net/2011/09/05/qgis-tips-custom-feature-forms-with-python-logic/
I managed to implement a simple QCompleter for a LineEdit in my form where the completer items are being fetched from DB (see init function code at the end of my mail).
This is very, very promising stuff which comes in quite handy for entering species names (from an official list of (thousands of) species names in my case)!
Yet there are two things I am struggling with:
1) Would it be possible to use this QCompleter solution to an autogenerated form? The auto generated forms are more than good enough for most of my use-cases. When I tried the Init function on an autogenerated form I got "NameError: global name 'TextEdit' is not defined"... Any ideas how to fix that?
2) It seems to me that the query - which is used to fill the QCompleter - is executed each time the form is opened. Would it be possible to avoid this, I mean that the query is only run once (e.g. when I open the project)? I hoped this could speed up the start of the form (even if the query gets cached in PostgreSQL)...
Many thanks in advance for helping.
Kind regards,
Stefan
P.S.: Next thing I will have to do is understand SIGNALS and SLOTS so I can adjust the completer content depending on other data entered in the form (e.g. filter species by kingdom or known occurrence in a country (here Norway)) ...
P.P.S.: My form_init.py looks like this:
from PyQt4.QtCore import *
from PyQt4.QtGui import *
from PyQt4.QtSql import *
import psycopg2
nameField = None
myDialog = None
def formOpen(dialog,layerid,featureid):
global myDialog
myDialog = dialog
global nameField
nameField = dialog.findChild(QLineEdit,"latinsk_navn")
#Initiate completer
completer = QCompleter()
nameField.setCompleter(completer)
#Fetch data from DB to fill completer
conn = psycopg2.connect("dbname='MYDB' user='MYUSERNAME' host='MYHOST' password='MYPASSWD'")
cur = conn.cursor()
cur.execute("""SELECT scientificname FROM kls.l_artsliste WHERE finnesinorge = 'Ja'""")
completition_items = []
for row in cur.fetchall():
completition_items.append(row[0])
#Add data to Qt Model / QCompleter
model = QStringListModel()
model.setStringList(completition_items)
completer.setModel(model)
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150328/fe7088b6/attachment.html>
