[Qgis-user] SQL Expressions
Nathan Woodrow
madmanwoo at gmail.com
Mon Mar 30 05:20:18 PDT 2015
Double quote is a field reference, single quote is a string. Functions
normally take a string for a field name, if you use "fieldname" that means
value of fieldname.
On Mon, 30 Mar 2015 at 22:07 Junior Delaz <delazj at gmail.com> wrote:
> Hi,
> Niccolo, Nathan is right. his proposal is the simplier and recommanded.
> But I think your formulae should work if you write
> $atlasfeatureid || '_' || attribute($atlasfeature, 'name' ).
> Only simple quote ' and not " near the field's name inside attribute
> function brackets.
> By the way, can someone explain me why for some functions (attribute,
> getFeature), you need to use simple quote for the fields and double
> quotes when using other functions ?
> And when you double-click on field's name, they are always appended to
> your expression with double quote. Can this be standardised ?
> 2015-03-30 12:02 GMT+02:00 Nathan Woodrow <madmanwoo at gmail.com>:
>> You don't need to use the attribute function to get the current feature
>> fields, just use the field name:
>> 'output_'|| "name"
>> "id" || "name"
>> On Sat, 28 Feb 2015 at 01:59 Niccolò Marchi <sciurusurbanus at hotmail.it>
>> wrote:
>>> Hi all,
>>> I'm having some problems with the new atlas SQL features and I feel like
>>> a dumb.
>>> before 2.6 I've been able to set the output name such as "feature id _
>>> feature name", but I can't understand (or make it work) with the new
>>> functions $atlasfeature and $atlasfeatureid.
>>> indeed, once started with the atlas production, a temporary image is
>>> created and then overwritten, leaving me with nothing.
>>> I tried with:
>>> $atlasfeatureid || '_' || attribute($atlasfeature, "name" )
>>> and then
>>> attribute( $atlasfeature, "id" ) || '_' || attribute( $atlasfeature,
>>> "name" )
>>> ("id" is a numeric field within the table)
>>> any suggestion?
>>> thank you in advance!
>>> all the best,
>>> Nic
>>> <http://www.avast.com/>
>>> This email is free from viruses and malware because avast! Antivirus
>>> <http://www.avast.com/> protection is active.
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150330/4f698571/attachment.html>
