[Qgis-user] Saga is not working
William Kyngesburye woklist at kyngchaos.com
Mon Mar 30 06:38:24 PDT 2015
What do you mean by "hang out"?  Does it not do anything and not return control to you?  Does it give you an error?  Does it run but not give you results?
One known issue with SAGA is that GDAL format plugins (MrSID, ECW, GRASS, ...) break the expected GDAL format order, so SAGA runs for a while, then gives an error that there is no output.
There is nothing to configure in the Terminal.  QGIS is a GUI app and has nothing to do with the Terminal.  SAGA configuration is done from the QGIS Processing menu, but it should be automatic.
On Mar 30, 2015, at 4:39 AM, azizul haque <haque.azizul320 at yahoo.com> wrote:
> I forgot to mention the QGIS version. plea find it in this mail below
> QGIS version	2.8.1-Wien	QGIS code revision
> Compiled against Qt	4.8.6	Running against Qt	4.8.6
> Compiled against GDAL/OGR	1.11.2	Running against GDAL/OGR	1.11.2
> Compiled against GEOS	3.4.2-CAPI-1.8.2	Running against GEOS	3.4.2-CAPI-1.8.2 r3921
> PostgreSQL Client Version	9.3.5	SpatiaLite Version	4.2.0
> QWT Version	6.0.2	PROJ.4 Version	480
> QScintilla2 Version
> On Sunday, 29 March 2015, 12:34, azizul haque <haque.azizul320 at yahoo.com> wrote:
> Hi All,
> As I told you I am now using QGIS 2.8.1. I have to do some analysis using SAGA under QGIS environment. Unfortunately it is not working. I mean when I run it immediately it goes hang out. I installed SAGA gis for Mac Pro and configure it on terminal. I assume that do not configure it right way.
> Any help is much appreciated.
> Please, please,
> Regards
> Azizul
> Qgis-user mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Oh, look, I seem to have fallen down a deep, dark hole.  Now what does that remind me of?  Ah, yes - life."
- Marvin
