[Qgis-user] pyqgis load error (Matthias Kuhn)
    Eugenio Trumpy
    frippe12573 at hotmail.com
    Tue Nov 10 07:48:07 PST 2015
Hi Matthias,
I tried:
git reset --hard d4b3
but I got many error on configuring with ccmake
So I update git pull again, now I got the version: b57d5ab
but the same error is present.
Any other hints?
Eugenio
> Hi Eugenio,
> Are you experienced enough with git to cherry-pick another commit and
> check if that fixes your issue?
> https://github.com/m-kuhn/QGIS/commit/d4b30c3e2c8334d4576bb7de4f2859f4827365e0
> Regards,
> Matthias
> On 11/10/2015 10:54 AM, Eugenio Trumpy wrote:
> > Hi everybody,
> > this morning I decided to compile qgis on my ubuntu 15.10 due to the fact
> > that the version I had: 2.13.0-master - 2bb0cf9, had problem with
> > grass process.
> > So I update the code & ccmake && make && make install, I had no errors
> > but launching
> > qgis I have the error:
> > Couldn't load PyQGIS.
> > Python support will be disabled.
> > getvalue() did not return a string
> > Python version:
> > 2.7.10 (default, Oct 14 2015, 16:09:02)
> > [GCC 5.2.1 20151010]
> > QGIS version:
> > 2.13.0-Master 'Master', 452e61c
> > Python path:
> > ['/usr/local/share/qgis/python', u'/home/eugenio/.qgis2/python',
> > u'/home/eugenio/.qgis2/python/plugins',
> > '/usr/local/share/qgis/python/plugins', '/usr/lib/python2.7',
> > '/usr/lib/python2.7/plat-x86_64-linux-gnu',
> > '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
> > '/usr/lib/python2.7/lib-dynload',
> > '/usr/local/lib/python2.7/dist-packages',
> > '/usr/lib/python2.7/dist-packages',
> > '/usr/lib/python2.7/dist-packages/PILcompat',
> > '/usr/lib/python2.7/dist-packages/gtk-2.0',
> > '/usr/lib/python2.7/dist-packages/ubuntu-sso-client',
> > '/usr/lib/python2.7/dist-packages/wx-3.0-gtk2']
> > Any hints on how to solve this problem?
> > best
> > Eugenio
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151110/ee48e682/attachment.html>
