[Qgis-user] coordinate conversion
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Thu Nov 12 20:32:20 PST 2015
That all depends, I guess on what version of WGS 84 datum the software uses to calculate the conversion. Most softwares don't even make a difference between wgs 84 and NAD 83. I would look at the conversion parameters carefully. Generally speaking, I would go with the governmental product as they must have a better control over stuff like GPS time and Continental drift...
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112 Fax: 514.381.4995
www.archeotec.ca
On Nov 12, 2015 13:01, "francesco_lucca [via OSGeo.org] " <ml-node+s1560n5236051h42 at n6.nabble.com> wrote:
I have a point in WGS84 UTM32 coordinate
E 589747.816
N 4871699.496
I saved in EPSG 3003 with the following coordinates:
E 1589776.553
N 4871716.117
A colleague made the same conversion using free software "traspunto" ( http://www.mondogis.com/traspunto.html ) developed by the Italian Enviromental Ministry. He got this result (EPSG 3003 coordinates):
E 1589776.054
N 4871716.382
I try another online tool ( http://www.sardegnageoportale.it/webgis/raswebconverter/index?stato_quale=punto ) and I found these EPSG3003 coordinates:
E 1589776.554
N 4871716.119
Summary: QGIS and sardegnageoportale seem to give the same results, traspunto is different (0.50 meter difference). Which is the correct result? Where can I found the calculation for the conversion from a system to another?
Thanks
Francesco
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/coordinate-conversion-tp5236051.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/coordinate-conversion-tp5236051p5236126.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151112/60649113/attachment.html>
