[Qgis-user] Projections Not Recognized
Alex Mandel tech_dev at wildintellect.com
Sun Nov 15 13:38:10 PST 2015
Those projections are not identical. NAD83 and NAD83_HARN differ, the
later having a higher precision do to corrections made to NAD83 in the
1990s.
Looking in QGIS I do see StatePlane HARN
EPSG:102348 for North
EPSG:102349 for South
Here's the prj I get making a fresh layer from EPSG:102348
PROJCS["Lambert_Conformal_Conic",GEOGCS["GCS_GRS 1980(IUGG,
1980)",DATUM["D_unknown",SPHEROID["GRS80",6378137,298.257222101]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Lambert_Conformal_Conic"],PARAMETER["standard_parallel_1",47.5],PARAMETER["standard_parallel_2",48.73333333333333],PARAMETER["latitude_of_origin",47],PARAMETER["central_meridian",-120.8333333333333],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["Meter",1]]
Hmm the standard parllel doesn't match.
So one of these isn't right.
http://epsg.io/102348
Maybe the definition in the EPSG/srs is wrong.
Anyone have a source to confirm what the correct parameters should be.
Alex
On 11/15/2015 11:57 AM, Clifford Snow wrote:
> Local governmental agencies in Washington State use the projection,
> Washington State Plane North and State Plane South. I believe they are
> ESRI: 102748 and 107349. When opened in QGIS they appear as USER:100001.
> These reference systems are included in the list (srs.db). I'm wondering
> why QGIS doesn't match.
> According to Spatial Reference the .prj is:
> PROJCS["NAD_1983_StatePlane_Washington_South_FIPS_4602_Feet",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137,298.257222101]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Lambert_Conformal_Conic"],PARAMETER["False_Easting",1640416.666666667],PARAMETER["False_Northing",0],PARAMETER["Central_Meridian",-120.5],PARAMETER["Standard_Parallel_1",45.83333333333334],PARAMETER["Standard_Parallel_2",47.33333333333334],PARAMETER["Latitude_Of_Origin",45.33333333333334],UNIT["Foot_US",0.30480060960121924]]
> A typical shapefile .prj file shows:
> PROJCS["NAD83_HARN_Washington_South_ftUS",GEOGCS["GCS_NAD83(HARN)",DATUM["D_North_American_1983_HARN",SPHEROID["GRS_1980",6378137,298.257222101]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Lambert_Conformal_Conic"],PARAMETER["standard_parallel_1",47.33333333333334],PARAMETER["standard_parallel_2",45.83333333333334],PARAMETER["latitude_of_origin",45.33333333333334],PARAMETER["central_meridian",-120.5],PARAMETER["false_easting",1640416.667],PARAMETER["false_northing",0],UNIT["Foot_US",0.30480060960121924]]
> Any suggestions on how to fix so QGIS recognizes these shapefiles
> would be appreciated.
> Thanks,
> Clifford
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
