[Qgis-user] Problems with Plugins
    Luigi Pirelli
    luipir at gmail.com
    Mon Nov 16 00:29:05 PST 2015
more data please,
on which platform, which qgis version
try also to run a "clean" qgis installation temporarly removing or renaming
<your user home>/.qgis2/ => then install/update plugins you want to use.
if you ar running with a master version (I suppose because of
https://github.com/qgis/QGIS/pull/2403/files), I strongly suggest to avoid
using master in production. You can always have problem like this because
it's a development version.
if not, probably you are using a Processing master version
(show_message_log was added in processing 24 days ago:
https://github.com/qgis/QGIS/blob/master/python/utils.py#L108) and the
problem can be solved upgrading/downgrading Processign to a version
compatible with your qgis.
please check
regards
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS:
https://www.packtpub.com/application-development/mastering-qgis
On 16 November 2015 at 03:19, Marta Modolo <marta.modolo at gmail.com> wrote:
> Hi to everybody,
> I contact you because i've got some problem with these plugins: Profile
> from points, Buffer by Percentage, clip multiple layers, dissolve with
> stats, multi-distante buffer and Processing. When I open QGis the program
> say me that: *Questo plugin รจ corrotto*
> cannot import name show_message_log
> Can you help me please?
> Thank you in advance
> Marta
> Marta Modolo
> PhD candidate in Cuaternario y Prehistoria
> Universitat Rovira i Virgili
> Avinguda Catalunya, 35
> 43002 Tarragona (Spain)
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151116/4fa1c50c/attachment.html>
