[Qgis-user] Load ESRI Personal Geodatabase in QGIS 2.8.1
Ulrike Assmann ua at umweltplan.de
Tue Nov 17 23:42:46 PST 2015
Hello Burghardt, Lewis and Randy,
thank you so much for your helpful answers. I have to check it now.
Ulrike
Am 17 Nov 2015 um 12:19 hat Burghardt.Scholle at stadt.wolfsburg.de geschrieben:
    Hi Ulrike,
    yes, it is possible to open a pGDB in QGIS. However, the versions of QGIS and MS
    Access must be the same: 32bit QGIS = 32bit Access vs. QGIS 64bit = 64bit MS
    Access.
    Greetings
    Burghardt
    Von: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag von Ulrike Assmann
    Gesendet: Dienstag, 17. November 2015 09:56
    An: qgis-user at lists.osgeo.org
    Cc: bs at hstumwelt.de
    Betreff: [Qgis-user] Load ESRI Personal Geodatabase in QGIS 2.8.1
    Dear list,
    I have a problem with opening a ESRI Personal Geodatabase with Annotation Layers in
    QGIS 2.8.1. I have tried to open it as vector layer:
    o          as "Datei/file" using "MDB" and also
    o          as "Datenbank/database" using type "ESRI-Personal-GeoDatabase", Might I have
    chosen an incorrect database connection? How do I fill the entry mask properly to make it
    work?
    I got the following error messages:
    o          first message: "ungültige Datenquelle/invalid data source"
    o          second message: "Verbindung fehlgeschlagen/connection failed".
    Is there even the possibility to open a ESRI Personal Geodatabase in QGIS?
    Many thanks
    Ulrike
