[Qgis-user] Using homebrew to install QGIS on El Capitan
    Jonas Pedersen
    dollarklavs at gmail.com
    Wed Nov 18 03:22:35 PST 2015
Has anyone tried to install QGIS using Homebrew?
I want to take advantage of the relative easy interplay between installed components/software when using Homebrew on the Mac, especially with database extensions and OSM2xxx utilities.
I have successfully installed QGIS using Homebrew but only when installing without any optional extras like grass7, orfeo, R, Saga GIS. I want to install with all these options because QGIS with an almost empty Processing toolbox is useless.
So my question is, Does anybody now of a solution or if there is any development on the issue (If not, I might have to look to KyngChaos distribution in the short run and Ubuntu in the long run). The official repository OSGeo/homebrew-osgeo4mac <https://github.com/OSGeo/homebrew-osgeo4mac> seems to a little deserted for the last couple of months.
Below is the error I get when installing with 'brew install qgis-28 --with-grass7 --with-orfeo --with-r --with-saga-gis':
==> Downloading http://grass.osgeo.org/grass70/source/grass-7.0.1.tar.gz
######################################################################## 100.0%
==> Patching
patching file include/Make/Install.make
Hunk #1 succeeded at 116 (offset 2 lines).
==> ./configure --prefix=/usr/local/Cellar/grass-70/7.0.1 --enable-shared --with-cxx --with-python --with-blas --with-lapack --with-sqlite --with-odbc --
==> make GDAL_DYNAMIC=
Last 15 lines from /Users/jonaspedersen/Library/Logs/Homebrew/grass-70/02.make:
/private/tmp/grass-7020151117-16810-13bmxin/grass-7.0.1/gui/wxpython/psmap
/private/tmp/grass-7020151117-16810-13bmxin/grass-7.0.1/gui/wxpython/rlisetup
/private/tmp/grass-7020151117-16810-13bmxin/grass-7.0.1/gui/wxpython/dbmgr
/private/tmp/grass-7020151117-16810-13bmxin/grass-7.0.1/gui/wxpython/vdigit
/private/tmp/grass-7020151117-16810-13bmxin/grass-7.0.1/gui/wxpython/iclass
/private/tmp/grass-7020151117-16810-13bmxin/grass-7.0.1/gui/wxpython/gcp
/private/tmp/grass-7020151117-16810-13bmxin/grass-7.0.1/gui/wxpython/timeline
In case of errors please change into the directory with error and run 'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Tue Nov 17 23:08:09 CET 2015
make: *** [default] Error 1
//Jonas
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151118/b47a3d86/attachment.html>
