[Qgis-user] a rogue layer
    Nicolas Cadieux
    nicolas.cadieux at archeotec.ca
    Sun Nov 22 16:07:10 PST 2015
Make sure you have CRS on the fly activated.  Install the openlayer  plugin and open a Google earth layer. (Notice that the project CRS will change).
Make sure you don't zoom in too much because the layer will shift.  Make sure your layer is well georeferenced.  Then try again with the CSV. Small shift between 20 to 200 meter can be caused by thing like using nad27 vs nad83. Try other projections for the file.  You can do that by right clicking on the layer (in the layer manager) and then changing the projection.
Good luck!
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112  Fax: 514.381.4995
www.archeotec.ca
On Nov 22, 2015 18:36, "Taryn Yaeger [via OSGeo.org]" <ml-node+s1560n5237940h1 at n6.nabble.com> wrote:
	<blockquote style="border-left:2px solid #cccccc;padding:0 1em" style="margin:0 0 0 0.8ex;border-left:1px #ccc solid;padding-left:1ex"> Hello. I'm working on a project, but I've been stopped in my tracks by a seemingly simple problem. I created a map of NYC using Sqlite files--all set to EPSG: 2263, but when I add a csv (SHL_PU in attached) and set it to the same CRS it does not match the previously added layers--it appears slightly to the west-- even though the CRS appears to be the same. I've tried to add the csv file innumerable times using different on the fly and project settings to no avail. I'd appreciate any help anyone has to offer. Even after searching through many discussion groups I've not yet found an answer to this problem. Any help would be deeply appreciated. Separately/relatedly, I'm interested in finding a qgis tutor. I'm flexible on schedule, frequency, and time commitment. If interested please contact me at [hidden email] . Thanks, Taryn
Qgis-user mailing list
[hidden email]
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user  test.zip (29K) Download Attachment
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/Re-a-rogue-layer-tp5237940.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Re-a-rogue-layer-tp5237940p5237941.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151122/72aa53c5/attachment.html>
