[Qgis-user] qgis server does not return any data from WFS
Andreas Neumann
a.neumann at carto.net
Wed Nov 25 05:50:49 PST 2015
Hi Jachym,
I believe this is a bug in the 2.12 release - or in the 2.12 ubuntu QGIS
package. Because 3 people reported it almost at the same time.
I just compiled master on my server and WFS works fine. So it's most
likely fixed in master but would have to be backported to 2.12.x release
and 2.8.4 release.
However, I don't know which commit fixed this issue.
Andreas
On 25.11.2015 14:37, Jachym Cepicky wrote:
> Andreas,
> thanks for clarification: I've not tedste GetPrint yet. Yes, GetMap
> works (without DISPLAY set)
> about location of .qgs file - I just use it locally, try to get owslib
> to work along with QGIS-WFS Server, so just for testing so far, but
> thanks for reminding me
> Jachym
> st 25. 11. 2015 v 14:02 odesílatel Andreas Neumann
> <a.neumann at carto.net <mailto:a.neumann at carto.net>> napsal:
> Hi Jachym,
> If WMS works (from the same project) and even GetPrint works, it
> shouldn't be the problem of the XServer or the DISPLAY variable.
> The XServer is required for printing as PDF (getPrint) and I
> believe also for rendering SVG symbols or patterns. X-Server (or
> an X-Server replacement, such XVNC) is required for QGIS Server -
> even if it is quite uncommon that an X-Server runs on a machine
> that also runs the Webserver.
> BTW: you should never put your .qgs project files in a path
> readable by the Webserver, but always outside. Just because you
> list /var/www/html - which is often the Server Root.
> .qgs files may contain sensitive information (such as db
> connections, passwords, etc.) and it shouldn't be downloadable
> from a web client.
> Andreas
> On 25.11.2015 13:48, Jachym Cepicky wrote:
>> Hi Andreas: yes, it's 2.12,
>> command line works:
>> QGIS_PROJECT_FILE=/var/www/html/tmp/pokus/vrstva.qgs
>> QUERY_STRING="SERVICE=WFS&REQUEST=GetFeature&TYPENAME=vrstva"
>> /var/www/cgi-bin/qgis_mapserv.fcgi
>> response as expected
>> Is it possible, that it's related to DISPLAY variable? I've seen
>> it in some documentation .. if set to :0 or :99 server returns
>> ServerError
>> Thanks
>> Jachym
>> st 25. 11. 2015 v 13:32 odesílatel Andreas Neumann
>> Since your are now the third person who has the same problem,
>> within the couple of days, I suspect that there really is a
>> bug in QGIS server in this particular release.
>> Is this on 2.12?
>> Andreas
>> On 25.11.2015 12:29, Jachym Cepicky wrote:
>>> hi Stefan,
>>> apache runs as www-data
>>> the file is accessible via
>>> http://localhost/tmp/pokus/vrstva.shp - so I assume, it is
>>> readable by www-data
>>> GetMap request as WMS works
>>> GetFeatureType as WFS does not
>>> thanks
>>> Jachym
>>> st 25. 11. 2015 v 11:38 odesílatel Blumentrath, Stefan
>>> <Stefan.Blumentrath at nina.no
>>> <mailto:Stefan.Blumentrath at nina.no>> napsal:
>>> Is /var/www/html/tmp/pokus/vrstva.shp readable for user
>>> “www-data” (which is the default user for accessing QGIS
>>> Server I assume)? Or is that the ‘apache user’ you
>>> referred to or did you configure apache to explicitly
>>> access through another user than ‘www-data’?
>>> Cheers
>>> Stefan
>>> *From:*Qgis-user
>>> [mailto:qgis-user-bounces at lists.osgeo.org
>>> <mailto:qgis-user-bounces at lists.osgeo.org>] *On Behalf
>>> Of *Jachym Cepicky
>>> *Sent:* 25. november 2015 11:28
>>> *To:* qgis-user at lists.osgeo.org
>>> <mailto:qgis-user at lists.osgeo.org>
>>> *Subject:* [Qgis-user] qgis server does not return any
>>> data from WFS
>>> Hi,
>>> several days, I'm fighting QGIS server - on lightttpd
>>> now on Apache server with *same* result: WFS
>>> GetFeatureType request does not return any data.
>>> I created project, set all necessary metadat, coordinate
>>> systems, made sure data are in readable path etc...
>>> I've published the service using qgis_mapserver.fcgi -
>>> WMS works (GetCapabilitiers, GetMap, GetFeatureInfo),
>>> but WFS works just for GetCapabilitiers, GetFeatureType
>>> request returns just the first response element
>>> <wfs:FeatureCollection
>>> xmlns:wfs="http://www.opengis.net/wfs" xmlns:ogc="h .....>
>>> and that's all - not even the closing tag. It seems, the
>>> server refuses to work in the middle of construction of
>>> the response :-(
>>> I have
>>> FcgidInitialEnv QGIS_AUTH_DB_DIR_PATH /var/www/qgis
>>> FcgidInitialEnv QGIS_DEBUG 1
>>> FcgidInitialEnv QGIS_SERVER_LOG_FILE /tmp/qgis-server.log
>>> FcgidInitialEnv QGIS_SERVER_LOG_LEVEL 1
>>> but /tmp/qgis-server.log is empty (even created)
>>> In the apache error log, only following lines can be found:
>>> Warning 1: Unable to find driver ECW to unload from
>>> GDAL_SKIP environment variable.
>>> Warning 1: Unable to find driver JP2ECW to unload from
>>> ERROR 4: Unable to open
>>> /var/www/html/tmp/pokus/vrstva.shp or
>>> /var/www/html/tmp/pokus/vrstva.SHP.
>>> BUT, accessing the file vrstva.shp from
>>> <http://localhost/tmp/pokus/vrstva.shp> works, apache
>>> user can read it and, as I already said: WMS GetMap and
>>> GetFeatureInfo works
>>> I've tested QGIS mapserver 2.12 and 2.8 on lightttpd as
>>> well as apache, with old projects as well as completely
>>> new with just one line in shapefile - same result all
>>> the time. Ubuntu 15.10 btw.
>>> Any hint?
>>> Thanks
>>> Jachym
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>> List info:http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe:http://lists.osgeo.org/mailman/listinfo/qgis-user
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151125/ce66d8c1/attachment.html>
