[Qgis-user] SOLVED: split features tool on postgres layer causes pkey violation
Janneke van Dijk
janneke.qgis at gmail.com
Fri Nov 27 02:02:49 PST 2015
Hi Bernd,
Indeed, that was the problem.
Running
SELECT setval('a_streets_streetsid_seq', COALESCE((SELECT
MAX(streetsid)+1 FROM a_streets), 1), false);
solved the issue. Still not sure what caused this in the first place,
but have added your trigger to the table for the future.
greetings,
Janneke
On 26/11/2015 18:32, Bernhard Ströbl wrote:
> Hi,
> I cannot confirm this behaviour neither with 2.8 on Win7 nor with 2.10
> on Linux. When asking the new features with the "i" tool after
> splitting, one keeps its pk value the other displays
> nextval("my_sequence"). Maybe the problem is that features have
> received pk values by other means then nextval("sequence"), thus the
> sequence's current start value is lower than the maximum pk value. To
> avoid such confusion I create a BEFORE INSERT or UPDATE trigger for my
> tables. This is the trigger function:
> CREATE OR REPLACE FUNCTION my_schema.my_table_ensure_sequence()
> RETURNS trigger AS
> $BODY$
> BEGIN
> IF (TG_OP = 'INSERT') THEN
> NEW.id:= nextval('my_id_seq');
> ELSIF (TG_OP = 'UPDATE') THEN
> NEW.id := OLD.id;
> END IF;
> RETURN NEW;
> END; $BODY$
> LANGUAGE plpgsql VOLATILE
> Users cannot manipulate the value of the id field anymore neither when
> INSERTing nor when UPDATEing.
> Bernhard
> Am 25.11.2015 um 20:14 schrieb Janneke van Dijk:
>> Dear all,
>> When using the split features tool in 2.10 and 2.12 on a postgres layer
>> (both on windows 7 and windows xp) I receive the following error after
>> trying to save the edits:
>> Could not commit changes to layer a_streets
>> Errors: ERROR: 1 feature(s) not added.
>> Provider errors:
>> PostGIS error while adding features: ERROR: duplicate key value violates
>> unique constraint "streets_pkey"
>> DETAIL: Key (streetsid)=(5) already exists.
>> The a_streets table has a serial primary key.
>> It seems similar to the bug described here:
>> https://hub.qgis.org/issues/5475
>> in 1.9 that was apparently fixed 3 years ago.
>> Is this indeed a bug? Or can the tool not be used on postgres layers?
>> Thanks for any insights,
>> Janneke
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> __________ Information from ESET Mail Security, version of virus
> signature database 12628 (20151126) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
