[Qgis-user] The XML of getcapabilities should not have any ascii code over 128
Matthias Kuhn
matthias at opengis.ch
Sun Oct 4 09:31:42 PDT 2015
Hi Andrea,
On 10/04/2015 05:55 PM, aperi2007 wrote:
> Hi Mattias,
> Sorry but this question is hard to understand for me .
> Perhaps I miss to analyze another step:
> If the operating system of the user is with a character set different
> from UTF8.
> And the user is editing a qgis project.
> The qgis project what character set is using ?
> AFAIK the qgis carset is set in the properties page of qgis.
Where exactly do you start experiencing strange behavior?
In the text box in the properties, in the project file or only in the
XML response from the server?
-- Matthias
> If this is true,
> How can the clipboard of the operating system to know what is the
> charset set in the properties page of qgis ?
> AFAIK the clipboard change always and only in the charset of the OS.
> A.
> Il 04/10/2015 15:30, Matthias Kuhn ha scritto:
>> Hi Andrea,
>> Is it really that there should only be 7bit characters or is it that the
>> encoding is not properly set in the answer?
>> XML fully supports utf-8 (it is even the default character encoding) and
>> I assume that in 2015 every modern XML client should support this as well.
>> Can you give an example server address and ideas of affected clients?
>> I have the feeling that there's something else fishy and if there is
>> really a need to replace characters above 127 then it should be an
>> opt-in configuration option.
>> Matthias
>> On 10/04/2015 11:59 AM, Andrea Peri wrote:
>>> Hi,
>>> we experienced this user case problem.
>>> In the qgis-server getcapabilities response the information of the
>>> "Abstract" is taken from the field:
>>> layer-properties -> metadata -> Abstract.
>>> But ofet the user fill this field with some cut/paste from other documents.
>>> So doing, if fill this field with many unacceptable character.
>>> Like these:
>>> or the very hard to see "no blank space".
>>> The qgis accept all of this without any problem,
>>> but when return the repsonse from a GetCapabiities request.
>>> The response is not valid for the xml.
>>> So many standard xml clients report a not well formed xml.
>>> We don't have any good ideas to how resolve this issue.
>>> My question is if could be possible in the qgis-server site to do a
>>> xml conversion of all this character.
>>> Instead of send them directly.
>>> AFAIK all of this could be coded to be corected coded in a XML response.
>>> Any thought on this ?
>>> Thx.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151004/f87c4487/attachment.html>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151004/f87c4487/attachment.sig>
