[Qgis-user] [GRASS-user] GRASS toolbar in QGIS
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Wed Oct 7 02:37:12 PDT 2015
Hi Radim,
Personally, I do not rely on the buttons in the toolbar, so I have no objections to remove them from the toolbar.
Consistent UI (comparable to Processing) seems an appropriate priority...
Just some ideas for possible solutions:
"Show Region button" might go into the "Region tab" in the grass tools widget (instead of near close mapset)?
Close to the "Close mapset"-button in the tools widget, you might place the "Open mapset"-button from the toolbar?
In a GRASS entry in an "Analysis" Menu, you might place content from the context menu in the browser (GRASS tools settings and so on)?
Cheers
Stefan
P.S.: I shall add that to the ticket...
-----Original Message-----
From: grass-user-bounces at lists.osgeo.org [mailto:grass-user-bounces at lists.osgeo.org] On Behalf Of Radim Blazek
Sent: 7. oktober 2015 11:09
To: qgis-user List <qgis-user at lists.osgeo.org>; grass-user <grass-user at lists.osgeo.org>
Subject: [GRASS-user] GRASS toolbar in QGIS
We are discussing possible UI cleanup related also to GRASS:
https://hub.qgis.org/issues/13537
Questions for plugin users:
- Can be open/new/close items removed from the toolbar? There is a possibility to open mapset from browser and close it from tools dock widget and there are menu items for all three actions.
- Should we keep Region action (region display on/off) in the toolbar, it could be moved to the top of tools widget, beside Close mapset button
- Is it "Open Tools" action in the toolbar useful? It is also in the menu and tools may be opened like any other docked widget from Settings > Panels
Radim
grass-user mailing list
http://lists.osgeo.org/mailman/listinfo/grass-user
