[Qgis-user] Aggregate tool not working
    Micah Duckworth
    micah.duckworth at askham-bryan.ac.uk
    Sat Oct 10 02:06:51 PDT 2015
I am a new Qgis user using the latest version. I am wanting to do a simple cell aggregation of a raster in order to use it in another application so have tried the aggregate algorithm.
First question: the parameter entry window does not show an option to specify the output file, as there is for other algorithms. Is it missing, or will it just output to a temporary file?
Secondly, the algorithm fails to run anyway! The log shows the following errors which seem to show failure to load dlls. What should I try?
Algorithm Aggregate starting...
grid_tools "Aggregate" -INPUT "C:\Users\m\AppData\Local\Temp\processing\e163dc05746341b68f5aff8371cebcb6\woodrasbinary.sgrd" -SIZE 3 -METHOD 0
C:\PROGRA~1\QGISPI~1\bin>set SAGA=C:/PROGRA~1/QGISPI~1/apps\saga
C:\PROGRA~1\QGISPI~1\bin>set SAGA_MLB=C:/PROGRA~1/QGISPI~1/apps\saga\modules
C:\PROGRA~1\QGISPI~1\bin>PATH=PATH;C:/PROGRA~1/QGISPI~1/apps\saga;C:/PROGRA~1/QGISPI~1/apps\saga\modules
C:\PROGRA~1\QGISPI~1\bin>saga_cmd grid_tools "Aggregate" -INPUT "C:\Users\m\AppData\Local\Temp\processing\e163dc05746341b68f5aff8371cebcb6\woodrasbinary.sgrd" -SIZE 3 -METHOD 0
ERROR 1: Can't load requested DLL: C:\PROGRA~1\QGISPI~1\apps\saga\dll\gdal_MrSID.dll
127: The specified procedure could not be found.
_____________________________________________
library path: C:\PROGRA~1\QGISPI~1\apps\saga\modules\grid_tools.dll
library name: Grid - Tools
tool name : Aggregate
author : Victor Olaya (c) 2005
Load grid: C:\Users\m\AppData\Local\Temp\processing\e163dc05746341b68f5aff8371cebcb6\woodrasbinary.sgrd...
Parameters
Grid system: 10; 6138x 6682y; 360035.92025x 447990.557700y
Grid: woodrasbinary
Aggregation Size: 3
Method: sum
C:\PROGRA~1\QGISPI~1\bin>exit
Converting outputs
Loading resulting layers
Algorithm Aggregate finished
The information in this email is confidential and is intended solely for the addressee, access to this email by anyone else is unauthorized. If you are not the intended recipient, you must not read, use or disseminate the information. Any views expressed in this message are those of the individual sender, please note that any views or opinions presented in this email may be personal to the author and do not necessarily represent the views or opinions of Askham Bryan College. It is the responsibility of the recipient to check this email for the presence of viruses; Askham Bryan College accepts no liability for any damage caused by any virus transmitted by this email.
http://www.askham-bryan.ac.uk/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151010/eba98148/attachment.html>
