[Qgis-user] GPS in QGIS
Jürgen E. Fischer
jef at norbit.de
Sun Oct 11 11:59:36 PDT 2015
Hi Sebastian,
On Sun, 11. Oct 2015 at 17:18:42 +0200, "Sebastian Teßmer" wrote:
> I own a Lenovo Pad with Windows. 8
> I'd like to use in QGIS the internal GPS of the PAD.
> Unfortunately this does not work.
> How do I set it? Do I still need a special driver?
> Or another program?
You're probably encountering http://hub.qgis.org/issues/7878. I suppose the
internal GPS works via the Windows Positioning API, which QGIS does not yet
support.
QGIS currently only supports GPS devices that speak NMEA on a serial port, gpsd
(local or remote gps on unix/linux) and the Qt positioning api (I think only on
Android).
On Windows some otherwise incompatible devices can be used with a driver that
creates a virtual serial port and produces NMEA on it. I don't know if
something like that exists for the Windows Positioning API.
Apparently so far no one had a strong necessity to develop that or fund someone
to do it.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151011/b6f9cc8d/attachment.sig>
