[Qgis-user] QGIS- How to render a raster using a field other than Value [SEC=UNCLASSIFIED]
    Andreas Neumann
    a.neumann at carto.net
    Tue Oct 13 23:32:15 PDT 2015
Hi Inna,
Do you mean based on a calculation (expression)?
Unfortunately, this is not possible yet. You'd have to calculate a new
raster file for that.
It would be an interesting addition to QGIS - if you really care about
it you might consider sponsoring this as a new feature. The expression
engine is already quite powerful in QGIS - so it should be possible.
Actually - there may be a workaround by (but not too intuitive). I
believe you can create a virtual raster file (VRT) where you can do
calculations. It is basically an XML file where you can mix/change
channels or do calculations on the raster. This is done on the fly. So
instead of loading your original raster - you would load the VRT file -
which contains and applies the calculations on the fly.
See http://www.gdal.org/gdal_vrttut.html
Hope this helps,
Andreas
On 14.10.2015 08:13, Inna Nogeste wrote:
> I would like to render my raster using a field that is not the Value
> field. Is it possible to do this in QGIS? This is easily done in ESRI
> ArcMap.
> I have access to both QGIS 2.10 and QGIS 2.8.
> Regards,
> *Inna Nogeste *| Spatial Information Specialist
> Description: Description: Description: cid:644484304 at 28112013-1D4C
> *Environmental Information Management***
> *Data Management
> Geospatial Data and Access Unit***
> Bureau of Meteorology
> www.bom.gov.au <http://www.bom.gov.au/>
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151014/52d6c142/attachment.html>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151014/52d6c142/attachment.gif>
