[Qgis-user] Copy field definitions from one vector layer to another?
Goyo
goyodiaz at gmail.com
Fri Oct 16 02:40:07 PDT 2015
2015-10-16 10:39 GMT+02:00 Alexandre Neto <senhor.neto at gmail.com>:
> uhmm... well thought! This will probably work if the geometry types of both
> layers are the same. If not, Instead of making an empty copy of the layer
> with attributes you should use a conversion tool to cast the layer into the
> desired final geometry, something like "polygon to line" or "Line to
> points", etc...
Yes, it was just an outline of the procedure. There may be some issues
to work around, depending on the details.
Goyo
