[Qgis-user] Set default view for Identify window?
Richard Duivenvoorde
richard at duif.net
Tue Oct 20 03:10:39 PDT 2015
On 20-10-15 11:52, Robin Wilson wrote:
> Hi,
>> can you tell us which views you are talking about.
> In QGIS 2.10, and the latest nightly build, when you choose the Identify map tool and click on the map, a docked window appears with the title 'identify results' and a tree-view showing the values of the various different layers. At the bottom of the docked window is a dropdown box labelled View, which has the options of Tree (the default), Table (a 'spreadsheet'-style table view) and Graph (pretty obvious). Like you, I don't like the tree view - and would love the option to choose which is the default.
Ok. I can only enable that dropdown once per QGIS session.
As soon as I have clicked on one object, I cannot change the dropdown
anymore.. And it changes to 'treeview' ??
Seems an issue?
Regards,
Richard
