[Qgis-user] Copy field definitions from one vector layer to another?
Luca Lanteri
mescal72 at gmail.com
Wed Oct 21 23:20:53 PDT 2015
ok, you are right.
You can import your shapfiles into spatialite using dbmanager, then copy
the definitions of the first layer, add column to the other layer and then
export to shapefile.
Luca
2015-10-22 5:17 GMT+02:00 Richard Males <rbmales at gmail.com>:
> The join works without a common field of any kind, which is what I wanted,
> but unfortunately the field names get prefixed with the join layer. When
> I export as shape file from the joined layer, I get field names like
> 'exported', 'exported_1', etc. So I don't think the join will work, since
> what I want to do is preserve field names, just copying them from one layer
> to another.
> Maybe some other approach? I was hoping for an existing plug-in, but
> have not found anything in the repository. Maybe a python script to
> export field names from existing layer? I will explore that approach,
> although I am not very familiar with python scripting for QGIS, see if I
> can get started.
> Thanks.
> On Tue, Oct 20, 2015 at 2:21 AM, Luca Lanteri <mescal72 at gmail.com> wrote:
>> why do you need the same geometry type in order to make a join ?
>> You just need one common field.
>> Luca
>> 2015-10-19 21:44 GMT+02:00 Joris Hintjens <jorishin at gmail.com>:
>>> I’d try “join layers” if they are the same geometry type
>>> Joris
>>> Op 17-okt.-2015, om 11:40 heeft Luca Lanteri <mescal72 at gmail.com> het
>>> volgende geschreven:
>>> You can make a join and then save as layer
>>> I have been looking for a capability (plugin or native QGIS) that will
>>> easily copy the field definitions (not the attribute data) from one layer
>>> to another layer. To date I have not found it, I may be missing something
>>> obvious. Any help/advice much appreciated.
>>> I have a layer with a bunch of fields already defined, and another layer
>>> with geometry but no additional fields. I would like to add the field
>>> definitions from the first layer to the second layer, and then populate
>>> with the appropriate data for that layer.
>>> Thanks.
>>> Dick Males
>>> Cincinnati, Ohio, USA
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151022/62fb346a/attachment.html>
