[Qgis-user] Unable to save project/export
Nathan Woodrow
madmanwoo at gmail.com
Thu Oct 22 21:44:00 PDT 2015
Where do you normally try and save to? Your home folder?
On Fri, Oct 23, 2015 at 2:30 PM, Orontes Mauricio Mejia <
mejiaorontes at hotmail.com> wrote:
> I have OS X Yosemite 10.10.5… my laptop has 8GB RAM if that matters, using
> QGIS 2.10.1… installed the GDAL complete 1.11, NumPy and
> matplotlib-1.4.3-1.. then the QGIS program…
> So since I’ve started using it… I’ve never been able save a project or use
> save as or even export as dxf…
> Either it says failed to export or Unable to save /xxx.extension ….
> I’ve tried rummaging around for people who have had similar problems but
> nothing…
> Someone please help me!.. If there’s no solution… I guess I’ll just use it
> to view shape files and tifs… and save as image… since that’s pretty much
> the only way I can use at this moment…
> and use ArcGIS if need be… *sobbing in a corner*
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151023/0c188228/attachment.html>
