[Qgis-user] QGIS plugin with python
Worth Lutz
wal3 at mindspring.com
Fri Oct 23 06:29:13 PDT 2015
Emilio,
Please reply to the QGIS users list so others will benefit from the
discussion. :)
Your next reading would probably be the QT4 and PyQt4 documentation for
the SQL database classes.
QT4 is the c++ version of the code.
PyQt4 is the python wrappers around QT4.
While you will be coding in python, the c++ documentation may be helpful
and clearer to read.
Google has been my friend. :)
Here are a few links to get you started.
http://doc.qt.io/qt-4.8/sql-connecting.html
http://pyqt.sourceforge.net/Docs/PyQt4/index.html
http://pyqt.sourceforge.net/Docs/PyQt4/qsqldatabase.html
http://stackoverflow.com/questions/7669987/what-is-the-correct-way-of-qsqldatabase-qsqlquery
I'm sorry don't have an example available at the moment. I cannot
promise I'll find the time to put one together.
*Worth Lutz*
On 10/23/2015 8:47 AM, Emilio S wrote:
> Thank you Worth Luz for your explanation. I have started with this and
> I have read a lot, but do you know any example to conect python with
> spatialite and do a SQL query?
> Thank you again
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151023/9ae64623/attachment.html>
