[Qgis-user] Problems with Qgis Server 2.12
Henrik Uggla
Henrik.Uggla at kristianstad.se
Tue Oct 27 03:43:29 PDT 2015
It seems to be caused by some file somewhere having wrong permissions. This error is from my Apache log:
ERROR: Auth db directory path could not be created
Googling the phrase I found this:
http://qgis.org/api/qgsauthmanager_8cpp_source.html
Where is this db directory path supposed to be created?
Henrik
________________________________________
Från: Qgis-user <qgis-user-bounces at lists.osgeo.org> för Andreas Neumann <a.neumann at carto.net>
Skickat: den 27 oktober 2015 05:37
Till: qgis-user at lists.osgeo.org
Ämne: Re: [Qgis-user] Problems with Qgis Server 2.12
Hi Henrik,
Any errors in the Apache log files? Or QGIS server log file?
Did you specify the map parameter or use an according Apache rewrite rule?
Is there an X-Server running?
Andreas
On 26.10.2015 22:11, Henrik Uggla wrote:
> I'm using Ubuntu 12.04 and upgraded Qgis Server from version 2.8.3 with Ubuntugis dependencies to 2.12 with Ubuntugis dependencies. Now no Qgis Server web services is working anymore. All I get when I try service=WMS&request=GetCapabilities is:
> <ServiceException code="WMS configuration error">
> There was an error reading the project file or the SLD configuration
> </ServiceException>
> Is anyone else experiencing this?
> Qgis-user mailing list
