[Qgis-user] Problems with Qgis Server 2.12
Alessandro Pasotti apasotti at gmail.com
Wed Oct 28 02:37:45 PDT 2015
2015-10-27 19:22 GMT+01:00 Larry Shaffer <larrys at dakotacarto.com>:
> Hi Henrik,
> This is due to the new authentication system in 2.12 [0], and the support
> I added to Server. When running Server, projects loaded that contain an
> authentication configuration (instead of clear text username/password) for
> accessing a secured resource, e.g. WMS using Basic Auth and HTTPS, need to
> be able to access the new 'qgis-auth.db'.
> The auth configurations are encrypted using a master password and stored
> in the qgis-auth.db, which by default is located at ~/.qgis2/qgis-auth.db
> for a desktop QGIS user. To enable Server support, I added two environment
> variables to overcome the problems associated with automatically loading
> projects [1], which are not yet fully documented:
Hi Larry,
thank you for the amazing new auth system, IMHO it really adds a lot of
value expecially for corporate users.
Recently we've spent quite some time trying to keep the server
documentation up-to-date:
http://docs.qgis.org/testing/en/docs/user_manual/working_with_ogc/ogc_server_support.html
(source:
https://github.com/qgis/QGIS-Documentation/blob/master/source/docs/user_manual/working_with_ogc/ogc_server_support.rst
It would be awesome if you could keep the manual in sync by adding the
information about the new auth system (new ENV vars etc.).
Also, please make sure that the apache.conf examples are still basically
working.
Thanks!
Alessandro Pasotti
w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151028/4c446ed8/attachment.html>
