[Qgis-user] Problems with Qgis Server 2.12
Larry Shaffer
larrys at dakotacarto.com
Wed Oct 28 08:37:59 PDT 2015
Hi Henrik,
On Wed, Oct 28, 2015 at 7:37 AM, Henrik Uggla <Henrik.Uggla at kristianstad.se>
wrote:
> I tried to set QGIS_AUTH_DB_DIR_PATH and the error message in the Apache
> log disappeared. I still got the "WMS configuration error" message though.
> It turned out to be the map parameter. In 2.8 you did not have to give
> the map parameter when there were only one .qgs-file was present.
> In 2.12 it is obviously mandatory. Thanks for your input!
Hmm. I thought I fixed that issue:
http://hub.qgis.org/issues/13291
The MAP param should not be mandatory if there is a .qgs project file in
the same directory as the qgis_mapserv.fcgi. Can you verify this? Also,
make sure the project is saved from 2.12 Desktop first, or possibly make a
new project just for testing.
If loading a project file from the same directory as the qgis_mapserv.fcgi
without using the MAP param does not work, please add a post to the above
noted ticket. Thanks.
Regards,
Larry Shaffer
Dakota Cartography
Black Hills, South Dakota
QGIS Support/Development | Boundless <http://boundlessgeo.com/>
> /Henrik
> *Från:* larry at shafferinteractive.com <larry at shafferinteractive.com> för
> Larry Shaffer <larrys at dakotacarto.com>
> *Skickat:* den 27 oktober 2015 19:22
> *Till:* Henrik Uggla
> *Kopia:* Andreas Neumann; qgis-user
> *Ämne:* Re: [Qgis-user] Problems with Qgis Server 2.12
> Hi Henrik,
> This is due to the new authentication system in 2.12 [0], and the support
> I added to Server. When running Server, projects loaded that contain an
> authentication configuration (instead of clear text username/password) for
> accessing a secured resource, e.g. WMS using Basic Auth and HTTPS, need to
> be able to access the new 'qgis-auth.db'.
> The auth configurations are encrypted using a master password and stored
> in the qgis-auth.db, which by default is located at ~/.qgis2/qgis-auth.db
> for a desktop QGIS user. To enable Server support, I added two environment
> variables to overcome the problems associated with automatically loading
> projects [1], which are not yet fully documented:
> * QGIS_AUTH_DB_DIR_PATH - Directory where an existing qgis-auth.db is
> located or created if not present. This directory needs to be *writeable*
> by Server's FCGI process user (which may differ from Apache's).
> * QGIS_AUTH_PASSWORD_FILE - File path to file with master password as
> first line. This is similar to password files used by database servers. The
> env variable is read during QGIS startup, then removed from the env
> variables space, so it is not available later on to the FCGI process or any
> Server plugins. Since all auth configurations are encrypted, a master
> password is required to access the qgis-auth.db, if a loaded project uses
> auth configs stored in the qgis-auth.db.
> What you have found is possibly a bug: the QGIS_AUTH_DB_DIR_PATH is now
> required to start Server, even if no loaded project make use of the new
> auth system. This is not really a bug if one considers the auth system
> setup mandatory from 2.12+, like it is on Desktop. At the minimum, a
> missing/non-writeable qgis-auth.db directory should throw a warning and not
> an error, allowing Server to launch.
> Please try setting QGIS_AUTH_DB_DIR_PATH to a directory writeable by the
> Server's FCGI process user and see if Server starts normally. Then check
> that qgis-auth.db is created in the directory.
> Here is how to set the env variables for the FCGI process in Apache [2,3].
> Note, setting them at the Apache process level will not work.
> [0]
> https://github.com/dakcarto/QGIS-Enhancement-Proposals/blob/auth-system/qep-14-authentication-system.rst
> [1]
> https://github.com/qgis/QGIS/blob/master/src/server/qgsserver.cpp#L359-L362
> [2] https://httpd.apache.org/mod_fcgid/mod/mod_fcgid.html#fcgidinitialenv
> [3] http://www.fastcgi.com/mod_fastcgi/docs/mod_fastcgi.html
> (-initial-env options)
> Regards,
> Larry Shaffer
> Dakota Cartography
> On Tue, Oct 27, 2015 at 4:43 AM, Henrik Uggla <
> Henrik.Uggla at kristianstad.se> wrote:
>> It seems to be caused by some file somewhere having wrong permissions.
>> This error is from my Apache log:
>> ERROR: Auth db directory path could not be created
>> Googling the phrase I found this:
>> http://qgis.org/api/qgsauthmanager_8cpp_source.html
>> Where is this db directory path supposed to be created?
>> Henrik
>> ________________________________________
>> Från: Qgis-user <qgis-user-bounces at lists.osgeo.org> för Andreas Neumann <
>> a.neumann at carto.net>
>> Skickat: den 27 oktober 2015 05:37
>> Till: qgis-user at lists.osgeo.org
>> Ämne: Re: [Qgis-user] Problems with Qgis Server 2.12
>> Hi Henrik,
>> Any errors in the Apache log files? Or QGIS server log file?
>> Did you specify the map parameter or use an according Apache rewrite rule?
>> Is there an X-Server running?
>> Andreas
>> On 26.10.2015 22:11, Henrik Uggla wrote:
>> > I'm using Ubuntu 12.04 and upgraded Qgis Server from version 2.8.3 with
>> Ubuntugis dependencies to 2.12 with Ubuntugis dependencies. Now no Qgis
>> Server web services is working anymore. All I get when I try
>> service=WMS&request=GetCapabilities is:
>> > <ServiceException code="WMS configuration error">
>> > There was an error reading the project file or the SLD configuration
>> > </ServiceException>
>> > Is anyone else experiencing this?
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151028/87337a36/attachment.html>
