[Qgis-user] QGIS- How to render a raster using a field other than Value [SEC=UNCLASSIFIED]
Damien Stephens
Damien.Stephens at sandfire.com.au
Thu Oct 29 17:10:26 PDT 2015
Fair enough. Good luck.
From: Inna Nogeste [mailto:I.Nogeste at bom.gov.au]
Sent: Friday, 30 October 2015 8:03 AM
To: Damien Stephens
Cc: qgis-user at lists.osgeo.org
Subject: RE: QGIS- How to render a raster using a field other than Value [SEC=UNCLASSIFIED]
Thanks Damien,
For the purposes of the product that I'm working on the preference is for the data to be maintained as a raster.
I've been using QGIS to test cartographic design and Map Server export (plugin) functionalities. It's worked fine for the data I've been given and what I've wanted to achieve except for the land use raster. I've needed to use ArcMap for the landuse raster data.
The MapServer plugin isn't working in QGIS 2.10 Pisa but was working in QGIS 2.8.
Regards,
Inna
(I've removed your screen grab from an earlier email as I keep on getting messages saying that this message is too big for this listing so don't know if any of the QGIS developers have seen this query).
From: Damien Stephens [mailto:Damien.Stephens at sandfire.com.au]
Sent: Wednesday, 28 October 2015 6:18 PM
To: Inna Nogeste
Cc: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
At this point my only suggestion is to convert the raster to polygons. Hopefully the text is maintained.
Could you send a clipped version of the raster to confirm?
Thanks
damien
From: Inna Nogeste [mailto:I.Nogeste at bom.gov.au]<mailto:[mailto:I.Nogeste at bom.gov.au]>
Sent: Wednesday, 28 October 2015 2:29 PM
To: Damien Stephens; qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Thanks for the suggestion. I've looked at it. Band = Band 1 (Gray) and there is no option to select a field or even input Values.
It would be good if QGIS could have the option of selecting a field to symbolise as this would be useful in raster data such as land use.
Inna
Sent: Tuesday, 27 October 2015 12:08 PM
To: Inna Nogeste; qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Ah ok the text field may cause a problem.
I don't have any rasters with text values to test. What happens when you try the paletted render type with text in the band rendering tab on the layer properties dialogue?
Cheers
Damien
Sent: Tuesday, 27 October 2015 7:34 AM
Hi Damien,
Thanks for your reply.
I am working with land use raster data which only has 1 band.
The values in the Value field have been attributed to a landuse (as a text attribute) in a newly created field which is what I want symbolise. In ESRI ArcMap, I can select whatever Value Field I want from a drop down list of fields in the raster data. It would be good to have a similar function in QGIS.
Inna
From: Damien Stephens [mailto:Damien.Stephens at sandfire.com.au]<mailto:[mailto:Damien.Stephens at sandfire.com.au]>
Sent: Wednesday, 14 October 2015 6:37 PM
If your raster has more than one value field (band) it should be pretty simple. The band rendering tab on the layer properties dialog lets you chose the band to colour.
In the attached screen grab I have chosen band 1 using a singleband pseudocolour render.
Hope that helps.
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org]<mailto:[mailto:qgis-user-bounces at lists.osgeo.org]> On Behalf Of Inna Nogeste
Sent: Wednesday, 14 October 2015 2:13 PM
To: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Subject: [Qgis-user] QGIS- How to render a raster using a field other than Value [SEC=UNCLASSIFIED]
I would like to render my raster using a field that is not the Value field. Is it possible to do this in QGIS? This is easily done in ESRI ArcMap.
I have access to both QGIS 2.10 and QGIS 2.8.
Regards,
Inna Nogeste | Spatial Information Specialist
Environmental Information Management
Data Management
Geospatial Data and Access Unit
Bureau of Meteorology
www.bom.gov.au<http://www.bom.gov.au/>
______________________________________________________________________
This email has been scanned by the Symantec Email Security.cloud service.
For more information please visit http://www.symanteccloud.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151030/e1fd4ebe/attachment.html>
