[Qgis-user] QGIS 2.12 packaging for Ubuntu 14.04?
Jürgen E. Fischer
jef at norbit.de
Fri Oct 30 08:17:06 PDT 2015
Hi Alex,
On Fri, 30. Oct 2015 at 07:48:43 -0700, Alex Mandel wrote:
> I think Jurgen decided to keep ubuntugis at the LTS and push the newer
> ones on qgis.org, since you can only have 1 version in a given repo.
No. The trusty build just with ubuntugis dependencies for amd64 build failed
with:
/usr/bin/ld: CMakeFiles/globeplugin.dir/globe_plugin.cpp.o: relocation R_X86_64_PC32 against undefined symbol `_ZNK8osgEarth13ConfigOptions9getConfigEv' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: final link failed: Bad value
collect2: error: ld returned 1 exit status
The i386 build was ok, but also not include because of the amd64 failure.
The 2.12 nightlies for ubuntugis trusty build fine however. So I suspect it
might have something to do building with debug vs without, but I didn't find
time yet to look into it.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151030/d4e4a9f8/attachment.sig>
