[Qgis-user] WMS
    Till Adams
    adams at terrestris.de
    Sat Oct 31 10:24:41 PDT 2015
Hi Kayla,
may be this is an issue of the WMS you are using. WMS'ses are often
restricted in max-pixel-output. Maybe your resolution and/or size of the
printout output is too big, so that QGIS requests a too large image from
the WMS. Then WMS doesn't give back a map-image.
Try a small output (small map) with a low resolution and check, if WMS
will be printed. If so, go up with resolution OR size.
So far, Till
Am 31.10.2015 18:20, schrieb Kayla Hanning:
> Hi,
> I'm new at QGIS, however, when I first began learning this program I
> was able to export my map with the WMS layer exporting. Now everytime
> I export my map from the print composer my WMS layer is not exporting.
> Leaving me just my shape files.
> Can anyone direct me the right way.
> thanks
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151031/49b49e4f/attachment.html>
