[Qgis-user] QGIS 2.10.1 adding PostGIS Views
Jürgen E. Fischer
jef at norbit.de
Tue Sep 1 01:59:43 PDT 2015
Hi James,
On Mon, 31. Aug 2015 at 15:05:05 -0400, James Keener wrote:
> I don't mind the behavior as much as it's entirely unclear, especially
> when the window is small and you have to scroll to see the drop down,
> what is the problem.
> There should be an error message (or even an error/warning icon with the
> tool tip saying there is on PK), along with possible remedies presented
> to the user.
Well, it's not an error (same as having to select a geometry type or SRID,
before being able to add a layer that doesn't have a 'proper' constraint).
And a tooltip is already there - although it could be more visible.
BTW the ticket for this is #11317.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150901/fcff7993/attachment.sig>
