[Qgis-user] QGIS 2.10.1 adding PostGIS Views
Jürgen E. Fischer
jef at norbit.de
Tue Sep 1 05:37:22 PDT 2015
Hi Sandro,
On Tue, 01. Sep 2015 at 13:48:33 +0200, Sandro Santilli wrote:
> I agree with Luca this should have been better not backported to 2.8.3.
> Only proper bugs should be backported, and this was a (debatable)
> GUI enhancement, as far as I can tell.
We intend to only backport fixes and not bugs. ;)
You were always supposed to select the key column - preselecting the first
column was the bug (also debatable). And #11317 is a ticket that demonstrates
there were unaware users.
That the first column often happens to be the primary key and and the combobox
is not lexically sorted is somewhat pure luck - and unless you avoid having the
key verified (using "use estimated metadata"), keeping a wrongly select
column will make the layer to insert invalid.
But I agree that the tooltip that you get on disabled lines (not only for the
key selection, but also geometry type and srid) might not be visible enough
(but that IMHO would be just a GUI enhancement).
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150901/2caada13/attachment.sig>
