[Qgis-user] DXF Export in QGIS 2.10
Andreas Neumann
a.neumann at carto.net
Tue Sep 1 06:11:51 PDT 2015
Hi again,
I had a small test again with QCAD and Draftsight and apparently they
just ignore/suppress the labels. So all of the three free CAD software
(QCAD/Draftsight/LibreCAD) seem to have issues with labels
The more capable CADs like Autocad or Vectorworks - or the GIS/CAD
converter FME display the labels fine.
Andreas
On 01.09.2015 15:06, Andreas Neumann wrote:
> Hi Thomas,
> libreCAD is extremely limited with its DXF Import and capabilities in
> general. Apparently it can't correctly deal with labels. QCAD or
> Draftsight do a slightly better job than libreCAD. The export was
> optimized for compatibility with Autocad and FME. This is our
> reference. They both read the files fine.
> You should ask at the libreCAD project, if they can't correctly read
> the DXF file.
> If we wouldn't export the Font/Text properties, the Autocad users
> would complain that the text does not match how it looked like in QGIS
> Andreas
> On 01.09.2015 14:59, Thomas Cürten (WhereGroup) wrote:
>> Hello everyboy,
>> I have a question towards the DXF Export in QGIS 2.10 . When I try to
>> export a project from QGIS into a DFX-file and open it in libreCAD,
>> the labels are not presented correctly. Some of them don't appear at
>> all, others are slightly dislocated and display further information
>> towards character type, hight and so on in front of the actual label
>> (e.g. Ubuntu|i0|b1;\H54.5776;/W0.75; Church).
>> Do you have any suggestions how i can avoid the additional
>> label-information, export all labels into the dfx-file and get them
>> in the right position?
>> Thanks
>> Thomas
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
