[Qgis-user] Adding a Mac to a group of PCs
Matthias Kuhn matthias at opengis.ch
Tue Sep 1 09:44:47 PDT 2015
Regarding relative paths to files and photos, it would be a quite
trivial - and useful - change to fix this.
If you would like to help funding this, please do not hesitate to
contact me.
Kind regards,
Matthias
On 09/01/2015 06:38 PM, didier peeters wrote:
> Arni,
> Postgis is certainly an excellent option.
> Regarding the data sources, currently QGis cannot use relative paths
> to files or photos (at least) but to svg's in styling (and maybe
> other, I don’t have an exhaustive list). One option to bypass the
> files issue would be to use a web server and store URL instead of
> internal paths.  For instance you could have a web server, and
> whenever a file (or photo) is added generate with a Postgresql trigger
> the corresponding url in another attribute, making the file available
> to all the users, either through a form or through an action.
> Didier
>> Le 1 sept. 2015 à 17:45, Árni Geirsson <arni at alta.is
>> <mailto:arni at alta.is>> a écrit :
>> Thanks Jim
>> Your answer encourages me to try the PostGIS option - it obviously
>> has some other useful advantages. But your reply also made me realize
>> that the problem is really that much of the data I have is on another
>> network share - hence the problem with the paths. I should simply
>> move the data so that everything is on the same share and and then,
>> relative paths will solve the problem.
>> Again, thank you for a very helpful answer.
>> Arni
>> Árni Geirsson
>> *Alta ehf* // +354 582 5000 // +354 897 9549
>> www.alta.is <http://www.alta.is/>  // Alta á Twitter
>> <http://twitter.com/alta_ehf> // Alta á Facebook
>> <http://www.facebook.com/pages/Alta/161795813838691?v=wall>
>> On Tue, Sep 1, 2015 at 3:26 PM, James Keener <jim at jimkeener.com
>> <mailto:jim at jimkeener.com>> wrote:
>>     Re: postgresql in my experience it's neither cumbersome nor slow.
>>     Feel free to email me for help if you would like to explore that
>>     route.
>>     Are the paths in you qgs file relative or absolute? If their
>>     relative, is the issue that the path separator is different? If
>>     that is the issue, I would file a bug report. (If they are
>>     absolute, try saving them with relative paths.)
>>     Jim
>>     On September 1, 2015 11:12:10 AM EDT, "Árni Geirsson"
>>     <arni at alta.is <mailto:arni at alta.is>> wrote:
>>         Hi
>>         I am adding a Mac to a local network of PCs. The Mac user
>>         uses QGIS (as well as the PCs) and accesses data on a shared
>>         drive. Now the problem comes up that data sources have
>>         different paths to the shared drive in each operating system,
>>         making cooperation difficult. On the other hand, since the
>>         .qgs file is easy to edit, some simple solution might map the
>>         paths automatically on open and back on save, to compensate
>>         for these differences. And maybe there is some other solution
>>         out there.
>>         I realize that having all shared data in PostGIS might be one
>>         way to solve this but I suspect that it might be both slower
>>         and a little more cumbersome.
>>         All thoughts and suggestions are highly appreciated.
>>         Árni Geirsson
>>         Qgis-user mailing list
>>         Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>         http://lists.osgeo.org/mailman/listinfo/qgis-user
>>     -- Sent from my Android device with K-9 Mail. Please excuse my
>>     brevity.
>> _______________________________________________ Qgis-user mailing
>> list Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150901/ab4c7eaa/attachment.html>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150901/ab4c7eaa/attachment.sig>
