[Qgis-user] QGIS 2.10.1 adding PostGIS Views
Andrea Peri
aperi2007 at gmail.com
Thu Sep 3 23:42:31 PDT 2015
Ho,
How do qgis to analyze the table to retrieve the unique?
A loop on every record or a SQL to count distinct ?
A.
Il 04/set/2015 08:01, "Bernhard Ströbl" <bernhard.stroebl at jena.de> ha
scritto:
> Am 03.09.2015 um 23:41 schrieb Sandro Santilli:
>> On Wed, Sep 02, 2015 at 08:48:34AM +0200, Bernhard Ströbl wrote:
>>> Am 01.09.2015 um 17:49 schrieb Matthias Kuhn:
>> 2. If there are tables without a PK open a second modal dialog with an
>>>> explanation of the problem and offer to select a pk from a combobox.
>>> I hope you mean "relation" not table, a table should always have a
>>> PK.
>> It's not mandatory for a table to have a PK.
>> I guess by "tables without a PK" he means table for which no PRIMARY
>> KEY constraint is explicitly defined (should an UNIQUE key be
>> considered equally valid?).
> It is not mandatory, of course, that's why I wrote "should", but IMHO it
> is very bad database design to not define one.
> There might be several UNIQUE constraints on one table but there can be
> only one PK constraint. So in case of only a UINIQUE constraint the table
> would be handled as any other without PK constraint (or QGIS needs to
> analyse how many fields have a UNIQUE constraint).
> Bernhard
> __________ Information from ESET Mail Security, version of virus signature
> database 12200 (20150904) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150904/13e6cc9f/attachment.html>
