[Qgis-user] QGIS 2.10.1 adding PostGIS Views
Jürgen E. Fischer
jef at norbit.de
Fri Sep 4 01:29:15 PDT 2015
Hi Andrea,
On Fri, 04. Sep 2015 at 10:18:31 +0200, Andrea Peri wrote:
> The first is to allow a standard access to a view only readonly .
That's already the case - but it doesn't solve that various other functions
(eg. attribute table, selection) also require a unique feature id.
> select count(distinct (field1, field2)) from view;
That's already done to verify that the manual pk selection is correct and leads
to and layer insertion error, if it's not. But that is often very expensive
and therefore is not done in the dialog. It's even not even verified in case
"use estimated metadata" is on in the connection.
> I complex step could be to link the field of the view to the field of a table.
What for?
> I guess this link is not provided directly from postgres.
It is - for simple fields. But there also are expressions (think: aggregates,
store procedures call etc.), that aren't covered. And there information about
the base fields doesn't tell you much about the situation in the view if there
are joins - a field unique in the base table is not necessarily unique in a
join with other tables.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150904/6aa2952e/attachment.sig>
