[Qgis-user] QGIS 2.10.1 adding PostGIS Views
Jürgen E. Fischer
jef at norbit.de
Fri Sep 4 03:06:13 PDT 2015
Hi Andrea,
On Fri, 04. Sep 2015 at 11:20:39 +0200, Andrea Peri wrote:
> Something like this (see image attached).
Hm, the problem seems to be that it's to much to ask a user to select one
unique key field of a view. Doesn't this make it even worse?
Letting him select multiple columns in the selection dialog and using those to
produce a unique feature id should be a relatively small task (pktFidMap is
already there, combobox can have checkable items), but doesn't solve the
problem at hand.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150904/50d28587/attachment.sig>
