[Qgis-user] Edit vertex using DMS coordinates Plugin?
Alexandre Neto
senhor.neto at gmail.com
Wed Sep 9 05:23:35 PDT 2015
I know NumericalDigitize and NumericalVertexEdit, but none of them allows
the user to input coordinates in DMS formats.
We receive coordinates in many formats, and mostly in some form of Degree,
minutes and deciimal Seconds, or Degree, and decimal minutes.
Normally I put the coordinates in a CSV and open it in QGIS to import the
coordinates. But It would be nicer the be able to add/edit them directly in
one of those format instead.
I did not know the node edit widget, looks interesting.
Thanks,
Alexandre
Em qua, 9 de set de 2015 às 12:22, Pedro Venâncio <pedrongvenancio at gmail.com>
escreveu:
> Hi Alexandre,
> Anyone know if it's possible or if there is a plugin that allow one to
>> introduce
> Have you tried NumericalDigitize plugin?
>> and modify vertex using introducing Degree, Minutes and Seconds (or any
>> other variation) values.
> For editing, we have in QGIS master the new Node editor widget [0], which
> has the Vertex editor list (i).
> I don't know if you can work with Degrees, Minutes and Seconds in any of
> them, but with decimal degrees they work well.
> Best regards,
> Pedro Venâncio
> [0] https://github.com/qgis/QGIS/pull/2217
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150909/60bbe1a7/attachment.html>
