[Qgis-user] featureCount() issue
Donovan Cameron sault.don at gmail.com
Thu Sep 10 11:45:03 PDT 2015
Do you have a sample dataset you can share for testing? Also, have you
tried it in the latest release or master?
Maybe check if there is an issue with multi-part vs single-part
geometries =)
Donovan
On 10/09/15 11:14 AM, Tudorache, Marian wrote:
> QGIS 2.8 – Linux 7
> Hi everyone,
> I observed the featureCount() returns wrong number of features from a
> layer.
> Is any fix for this?
> Thanks,
> Marian
> This electronic message, as well as any transmitted files included in
> the electronic message, may contain privileged or confidential
> information and is intended solely for the use of the individual(s) or
> entity to which it is addressed. If you have received this electronic
> message in error please notify the sender immediately and delete the
> electronic message. Any unauthorized copying, disclosure or
> distribution of the electronic message is strictly forbidden. NAV
> CANADA accepts no liability for any damage caused by any virus and/or
> other malicious code transmitted by this electronic communication.
> Le présent message électronique et tout fichier qui peut y être joint
> peuvent contenir des renseignements privilégiés ou confidentiels
> destinés à l’usage exclusif des personnes ou des organismes à qui ils
> s’adressent. Si vous avez reçu ce message électronique par erreur,
> veuillez en informer l’expéditeur immédiatement et supprimez le. Toute
> reproduction, divulgation ou distribution du présent message
> électronique est strictement interdite. NAV CANADA n’assume aucune
> responsabilité en cas de dommage causé par tout virus ou autre
> programme malveillant transmis par ce message électronique.
> Qgis-user mailing list
Kind regards,
Donovan
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150910/c5bd3faf/attachment.html>
