[Qgis-user] Making oblique maps in Qgis: is it possible?
    Raymond Nijssen
    r.nijssen at terglobo.nl
    Fri Sep 11 03:57:10 PDT 2015
Hi Jens,
Could you post an example of what you are looking for?
Actually, I don't think QGIS can do such maps but maybe it is possible
using some user defined map projection.
Also have a look at the Globe plugin:
https://www.youtube.com/watch?v=ZDDe-sVogNU
Regards,
Raymond
On 11-09-15 11:00, Jens Verwaerde | Natuurpunt CVN wrote:
> I'd like to make an oblique (bird's eye) view of some of my maps.
> Theoretically this is possible by exporting a map to an image manipulation
> program and then using a tilting function, but ... that's an extra step and
> ... everything on the map is then "obliqued" including labels etc.
> But I don't want everything to become oblique; text labels, arrows etc.
> should stay "normal" and floating in the air above the map, so only the map
> should be oblique.
> Also is it possible to have diagrams that "point from the sky" to the
> location on the oblique map instead of also becoming oblique?
> Jens Verwaerde
> lesgever natuurbeheer en natuurfotografie
> t: 015 29 72 29 | gsm: 0491 15 03 57
> Website: http://cvn.natuurpunt.be
> Facebook: www.facebook.com/NatuurpuntCVN
> Qgis-user mailing list
Terglobo
Ampèrestraat 110
5223 CT 's-Hertogenbosch
06-25314983
