[Qgis-user] Edit vertex using DMS coordinates Plugin?
Alexandre Neto
senhor.neto at gmail.com
Fri Sep 11 12:57:36 PDT 2015
Making a plugin might be an idea. Or some improve the numericalvertexedit
and numerical digitize plugins.
I will have a look into all your code.
Meanwhile, what is the name of your plugin? It sound useful fot mem.
Thanks
A 19h34 Sex, 11 de Set de 2015, Tudorache, Marian <
Marian.Tudorache at navcanada.ca> escreveu:
> Hi,
> I am sorry to interfere in this thread but I think my findings will help
> you.
> I also want to report a possible bug.
> I have worked to a plugin which display the coordinate in DMS when the
> user execute a mouse left click on the map.
> When the geometries are displayed on the projection, the conversion on the
> fly to DMS does not work properly.
> To have properly displayed the coordinate in DMS or Decimal degree you
> need to re-project your data to a coordinate reference system (WGS84 or
> GRS80, or other).
> For example:
> If data is displayed in projection reference system (stereographic in my
> case) and data is stored in world coordinates system (X and Y).
> X = -1081940.67048 and Y = 2561405.89514 will be displayed as 140040’13.726
> W. *There is not such latitude2561405053’42.489 N*
> *This is the projection: *+proj=sterea +lat_0=53.5 +lon_0=-76.0 +k=1
> +x_0=0 +y_0=0 +a=6381816.160744 +b=6381816.160744 +units=m +no_defs
> The conversion is done by the function toDegreesMinutesSeconds from
> QsgPoint class.
> It looks the function is not able to do to re-projection back to the
> spheroid. I think this is a bug.
> The function toDegreesMinutesSeconds works properly if it is applied to
> Decimal degree coordinate.
> What to be done!
> First you need to reproject your data by using QgsCoordinateTransform .
> Ex.
> crs = qgis.core.QgsCoordinateRefernceSystem(<idCRS>, qgis.core.
> QgsCoordinateRefernceSystem.InternalCrsId) # if you use a customized
> prs = qgis.core.QgsCoordinateRefernceSystem(<idPRS>, qgis.core.
> projected reference system
> transformation = = qgis.core. QgsCoordinateTransform(crs, prs)
> #transformation object is used to re-project your coordinates.
> For example:
> point = qgis.core.QgsPoint(X, Y) # X and Y are in world coordinate system
> meters
> #apply transformation to reproject your point
> reprojectedPoint = transformation.transform(point,
> QgsCoordinateTransform.ForwardTransform)
> print reprojectedPoint #you will get the point in decimal degrees.
> pointDMS = reprojectedPoint. toDegreesMinutesSeconds(3, True, True) #your
> will get the point in degrees minutes seconds with respect to crs
> if you want to input DMS data then you have to do the same steps but in
> reverse:
> 1. Convert DMS to decimal degrees;
> 2. Apply QgsCoordinateTransform to decimal degrees so you get X and
> Y.
> You can build a plugin based on this class. Check out the function
> drawLine where I input a lat and long in DMS format and write the line
> geometry in x/y format. If you have write your geometry in lat and long
> decimal degrees you do not have to apply QgsCoordinateTransform.
> #spam_activate_map_background
> import qgis
> from PyQt4 import QtGui, QtCore
> class LineGeometryDMSInput:
> def __init__(self):
> self.__prs = qgis.core.QgsCoordinateReferenceSystem(100006,
> qgis.core.QgsCoordinateReferenceSystem.InternalCrsId)
> self.__crs = qgis.core.QgsCoordinateReferenceSystem(100000,
> self.__transformation = qgis.core.QgsCoordinateTransform(self.__
> prs , self.__ crs)
> def drawLine(self, lineStartDMS, lineEndDMS):
> start_Point = lineStartDMS.split(',')
> end_Point = lineEndDMS.split(',')
> startLine = (self.fromDmsToDecimal(start_Point[0], 5),
> self.fromDmsToDecimal(start_Point[1], 5))
> endLine = (self.fromDmsToDecimal(end_Point[0], 5),
> self.fromDmsToDecimal(end_Point[1], 5))
> line_start = qgis.core.QgsPoint(startLine[1], startLine[0])
> line_end = qgis.core.QgsPoint(endLine[1], endLine[0])
> pointGeomStartTransformed = self.__
> transformation.transform(line_start,
> qgis.core.QgsCoordinateTransform.ForwardTransform)
> pointGeomEndTransformed = self.__
> transformation.transform(line_end,
> layer = qgis.utils.iface.activeLayer()
> latestID = int(layer.featureCount())
> layer.startEditing()
> caps = layer.dataProvider().capabilities()
> if caps & qgis.core.QgsVectorDataProvider.AddFeatures:
> featureLine = qgis.core.QgsFeature(layer.pendingFields())
> geom =
> qgis.core.QgsGeometry.fromPolyline([pointGeomStartTransformed,
> pointGeomEndTransformed])
> #if your data is stored in geographical coordinate use this
> #geom = qgis.core.QgsGeometry.fromPolyline([line_start,
> line_end])
> featureLine.setGeometry(geom)
> layer.dataProvider().addFeatures([featureLine])
> layer.commitChanges()
> layer.updateExtents()
> qgis.utils.iface.zoomToActiveLayer()
> def fromDmsToDecimal(self, dmsString, precision):
> degree = float(dmsString.strip()[:2])
> decimal_minutes = float(dmsString.strip()[2:-9])
> decimal_seconds = float(dmsString.strip()[5:-2])
> decimal = round(degree + decimal_minutes/60 +
> decimal_seconds/3600, precision)
> if 'S' in dmsString or 'W' in dmsString:
> decimal = decimal * (-1.0)
> return decimal
> Thanks,
> Marian
> *From:* qgis-user-bounces at lists.osgeo.org [mailto:
> qgis-user-bounces at lists.osgeo.org] *On Behalf Of *Alexandre Neto
> *Sent:* September-09-15 8:24 AM
> *To:* Pedro Venâncio
> *Cc:* QGIS User
> *Subject:* Re: [Qgis-user] Edit vertex using DMS coordinates Plugin?
> I know NumericalDigitize and NumericalVertexEdit, but none of them allows
> the user to input coordinates in DMS formats.
> We receive coordinates in many formats, and mostly in some form of Degree,
> minutes and deciimal Seconds, or Degree, and decimal minutes.
> Normally I put the coordinates in a CSV and open it in QGIS to import the
> coordinates. But It would be nicer the be able to add/edit them directly in
> one of those format instead.
> I did not know the node edit widget, looks interesting.
> Thanks,
> Alexandre
> Em qua, 9 de set de 2015 às 12:22, Pedro Venâncio <
> pedrongvenancio at gmail.com> escreveu:
> Hi Alexandre,
> Anyone know if it's possible or if there is a plugin that allow one to
> introduce
> Have you tried NumericalDigitize plugin?
> and modify vertex using introducing Degree, Minutes and Seconds (or any
> other variation) values.
> For editing, we have in QGIS master the new Node editor widget [0], which
> has the Vertex editor list (i).
> I don't know if you can work with Degrees, Minutes and Seconds in any of
> them, but with decimal degrees they work well.
> Best regards,
> Pedro Venâncio
> [0] https://github.com/qgis/QGIS/pull/2217
> This electronic message, as well as any transmitted files included in the
> electronic message, may contain privileged or confidential information and
> is intended solely for the use of the individual(s) or entity to which it
> is addressed. If you have received this electronic message in error please
> notify the sender immediately and delete the electronic message. Any
> unauthorized copying, disclosure or distribution of the electronic message
> is strictly forbidden. NAV CANADA accepts no liability for any damage
> caused by any virus and/or other malicious code transmitted by this
> electronic communication.
> Le présent message électronique et tout fichier qui peut y être joint
> peuvent contenir des renseignements privilégiés ou confidentiels destinés à
> l’usage exclusif des personnes ou des organismes à qui ils s’adressent. Si
> vous avez reçu ce message électronique par erreur, veuillez en informer
> l’expéditeur immédiatement et supprimez le. Toute reproduction, divulgation
> ou distribution du présent message électronique est strictement interdite.
> NAV CANADA n’assume aucune responsabilité en cas de dommage causé par tout
> virus ou autre programme malveillant transmis par ce message électronique.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150911/f6156fe0/attachment.html>
