[Qgis-user] to change the location of several points on a map
Tony Pham
tony_n_pham at yahoo.com
Tue Sep 15 17:38:31 PDT 2015
Hi Natalia,
I am not familiar with the Azimuth and Distance tool within QGIS. However, given that you have multiple posiciones inicial by which you need to determine the posiciones final, have you considered taking your data set and placing it into a spatial database such as PostGIS? PostGIS has a function called ST_Project (http://postgis.net/docs/ST_Project.html) which should be able to address your needs.
Good luck,-Tony
On Tuesday, September 15, 2015 7:30 PM, Schroeder Natalia <natalias at mendoza-conicet.gob.ar> wrote:
Hello,
My question is the following.
I need to change the location of several points on a map. I mean, for each point from a list, I have the distance from the initial position towards a new final position (a line) and the angle to the North (Azimuth) of that line. What I want is to know the X and Y coordinates of the new final position, in order to put that point into the new position. And I have too many points (over 1000) to do it manually.
It this clear?
This is the scheme (in Spanish, sorry):
As I understand, the Azimuth and Distance tool 'draws' points based on azimuths and distances, but guided by the immediately preceding point as reference. And it does not help me, because I need taking the points independently, not in relation to the previous one, because my points are independent observations. Is it correct or am I misunderstanding the tool?
Any idea to solve this problem?
Thanks in advance
Natalia
Natalia M. Schroeder
Laboratorio de Interacciones Ecológicas (LIE)
Instituto Argentino de Investigaciones de las Zonas Áridas (IADIZA), CONICET
CC 507, CP 5500, Mendoza, Argentina.
TE: +54-261-5244166
http://personal.mendoza-conicet.gob.ar/natalias/
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150916/e28d5569/attachment.html>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150916/e28d5569/attachment.png>
