[Qgis-user] Maximum string length 254
    Giulia Barbero
    giulybarbero at hotmail.it
    Thu Sep 17 07:20:43 PDT 2015
Hello,
I'm using Q-GIS 2.10.1 and I have a problem. I have a shapefile with datas from a company and in the list of attributes tehre is described the geometry (I mean, there are all the coordinates). The problem is that the maximum length of the string is set to 254 and because of this I loose information if teh line has a complicated geometry. Do you know if there a solution, maybe by creating the attribute in another way or by using different types of files ( for example using spatialite) ? I need the coordinates of each line...
Thank you
Giulia
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150917/164a9a82/attachment.html>
