[Qgis-user] About QgsGeometry::buffer
Tudorache, Marian Marian.Tudorache at navcanada.ca
Fri Sep 18 14:12:33 PDT 2015
Hi everyone,
I would like to find more details about QgsGeometry::buffer with more styles.
In QGIS API Documentation there are two version of the buffer:
Simple version with distance and segments and with sytles.
The one with styles is defines as: ( distance, segments, endCapStyle, joinStyle, mitreLimit );
I do not understand the followings parameters:
endCapStyle: Round (1) / Flat (2) / Square (3) end cap style
joinStyle: Round (1) / Mitre (2) / Bevel (3) join style
mitreLimit: Limit on the mitre ratio used for very sharp corners
Does someone has some examples or recommend a book where to find more details please?
The QGIS API Documentation does not give me too much.
Thanks,
Marian
This electronic message, as well as any transmitted files included in the electronic message, may contain privileged or confidential information and is intended solely for the use of the individual(s) or entity to which it is addressed. If you have received this electronic message in error please notify the sender immediately and delete the electronic message. Any unauthorized copying, disclosure or distribution of the electronic message is strictly forbidden. NAV CANADA accepts no liability for any damage caused by any virus and/or other malicious code transmitted by this electronic communication.
Le pr?sent message ?lectronique et tout fichier qui peut y ?tre joint peuvent contenir des renseignements privil?gi?s ou confidentiels destin?s ? l'usage exclusif des personnes ou des organismes ? qui ils s'adressent. Si vous avez re?u ce message ?lectronique par erreur, veuillez en informer l'exp?diteur imm?diatement et supprimez le. Toute reproduction, divulgation ou distribution du pr?sent message ?lectronique est strictement interdite. NAV CANADA n'assume aucune responsabilit? en cas de dommage caus? par tout virus ou autre programme malveillant transmis par ce message ?lectronique.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150918/a27dda99/attachment.html>
