[Qgis-user] Concatenate address fields with NULLS
DelazJ
delazj at gmail.com
Mon Sep 21 00:57:35 PDT 2015
Hi Andreas,
2015-09-21 8:39 GMT+02:00 Andreas Neumann <a.neumann at carto.net>:
> Hi,
> So how is concat(NULL,fieldname) any better than COALESCE(fieldname,'').
> To me it is the same complexity and not really an improvement. But maybe I
> don't get it. The only slight advantage would be that "concat" may be a
> more familiar term than coalesce. But if you come from a database
> background you already know COALESCE. Any serious GIS professional needs to
> know databases.
> Concatenate labels is a frequent question in GIS forums. Maybe we are not
all _serious_ GIS professional but even QGIS _simple_ users should be able
to easily concatenate labels without being puzzled by NULL values handling
imho.
> Another small thing:
> Do not mix up double quotes (") and single quotes ('). Whenever you use a
> string, do use single quotes, when you use an attribute either use no
> quotes or double quotes for some providers if you use capital letters in
> field names (which is discourage anyway).
> Andreas
> On 20.09.2015 12:59, Matthias Kuhn wrote:
> Hi Phil,
> In addition to COALESCE I'd like to promote the use of the function
> *CONCAT()* which treats NULL values as empty strings (it was changed
> recently, it's probably since 2.10) what makes it very handy.
> Example:
> NULL || "hello" -> NULL
> vs.
> CONCAT( NULL , "hello") -> "hello
> vs.
> COALESCE( NULL, "" ) || "hello" -> "hello"
> Cheers,
> Matthias
> On 09/20/2015 09:54 AM, Phil (The Geek) Wyatt wrote:
> Hi Folks,
> I am working with LIST Address Points data from
> http://listdata.thelist.tas.gov.au/opendata/ (Specifically Clarence
> Municipality) and I need to concatenate into one field the full address of
> each location. I am struggling to figure out how to do it when there are
> fields for unit numbers, building names, numbers to and from etc. Many of
> the fields are also NULL so clearly I want those fields disregarded.
> Can someone give me a quick heads up on how to NOT add the data from a
> field that has NULL?
> Chances are I will be doing this regularly so I am keen to document the
> required expressions for others to use as well.
> Cheers - Phil
> Volunteer Mapper - Red Cross
> <http://www.redcross.org.au/volunteering.aspx>
> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150921/2fd000bb/attachment.html>
