[Qgis-user] Geoprocessing dissolve tool
Bernhard Ströbl
bernhard.stroebl at jena.de
Mon Sep 21 02:11:55 PDT 2015
I worked on the dissolve tool recently , and the work got commited a
couple days ago [1]
So, if you are using current master, you must set the dissolve field for
the layer. If you are using a stable version of QGIS (e.g. 2.10) you
must untick the checkbox "Dissolve all (do not use field)". I recommend
to use my patch because it is a lot faster than the old algorithm.
Bernhard
[1]
https://github.com/qgis/QGIS/commit/116089e6ec0bd9bfd15395206bd6e880561da859
Am 21.09.2015 um 10:42 schrieb Julie Pierson:
> Hi all,
> I tried using the dissolve tool from the QGIS geoprocessing tools and
> all features get dissolved together, resulting in only one feature,
> regardless of the dissolve field. I tried with several datasets. Do you
> have the same problem or is it only me ? I've used this tool in the
> past, and it worked ok.
> Thanks for your help !
> Julie.
> Qgis-user mailing list
__________ Information from ESET Mail Security, version of virus signature database 12285 (20150921) __________
The message was checked by ESET Mail Security.
http://www.eset.com
