[Qgis-user] What's wrong with PRJ file for CRS 3857?
    Redoute
    redoute at tortenboxer.de
    Mon Sep 21 03:16:04 PDT 2015
Am 17.09.2015 um 05:54 schrieb Andre Joost:
Meanwhile I did some research, this is what I understand:
> No, both WKT definition and proj.4 definition are not capable of
> defining the transition from ellipsoid to spheroid in the way Google
> uses it.
Proj4 can: "+nadgrids=@null" is hackish, but I think it does the right
thing using a current Proj4. This is what makes the WKT with Proj4
extension working.
WKT without Proj4-String also can, but you have to give an applicable
PROJECTION parameter, and the software has to implement it. From what I
found on the net, ESRI named their method "Mercator_Auxiliary_Sphere".
GDAL seems to provide no matching method, but not sure about this.
epsg-registry.org now provides WKT strings following the current WKT
standard <http://docs.opengeospatial.org/is/12-063r5/12-063r5.html>. It
uses 'CONVERSION["Popular Visualisation Pseudo-Mercator",
METHOD["Popular Visualisation Pseudo Mercator",ID["EPSG",1024]]'. This
form of WKT is a very recent standard, I don't know which software
currently has support for it. "Operation Method" EPSG 1024 is a textual
description with formulas, how the conversion has to be done. It can be
implemented independent of WKT version.
Redoute
