[Qgis-user] Python Skript for Saving
Carlos López PSIG
carlos.lopez at psig.es
Thu Sep 24 10:13:55 PDT 2015
Yes, but It's better in list, always somebody that could correct me!!!
Firstly you must to visit this website:
http://www.gdal.org/index.html
Then, probably you need to use gdal_translate for convert rasters.
If you use windows you could write a bat for to do a list of conversions...
If you have linux you must to do a shell.
For example (bat for convert a lots of Mr Sid to TIF):
*set SRC=25831*
*REM start for*
*for /R %%f in (*.sid) do (*
*REM convert to geotif*
*call gdal_translate -a_srs EPSG:%SRC% "%%f" "%%~dpnf.tif" -co
COMPRESS=JPEG -co JPEG_QUALITY=60 -co BLOCKXSIZE=128 -co BLOCKYSIZE=128*
*REM create pyramides*
*call gdaladdo -r average --config COMPRESS_OVERVIEW JPEG --config
PHOTOMETRIC_OVERVIEW YCBCR --config INTERLEAVE_OVERVIEW PIXEL --config
JPEG_QUALITY_OVERVIEW 80 "%%~dpnf.tif" 2 4 8 16 32 64 128 256*
Good luck,
* <http://www.psig.es>*
*Carlos López Quintanilla*
www.psig.es
+34 699.680.261
2015-09-24 19:02 GMT+02:00 "Sebastian Teßmer" <SebastianTessmer at gmx.de>:
> Hi, thanks for your answer! Can you tell me maybe a little more detail,
> how exactly I can implement that? Thank Sebastian
> Diese Nachricht wurde von meinem Android Mobiltelefon mit GMX Mail
> gesendet.
> "Carlos López PSIG" <carlos.lopez at psig.es>schrieb:
>> Hi Sebastian,
>> You could use gdal library directly!
>> Best regard,
>> * <http://www.psig.es> *
>> www.psig.es
>> +34 699.680.261
>> 2015-09-24 16:43 GMT+02:00 "Sebastian Teßmer" <SebastianTessmer at gmx.de>:
>>> Hello there,
>>> I want to write a script that uses the "Save As" dialog.
>>> What is the command for this in the Python console?
>>> I want to store a lot of pictures, so they can be used offline.
>>> Perhaps there is already a script for this?
>>> Many thanks,
>>> Sebastian
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> _______________________________________________ Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150924/fbb34b09/attachment.html>
